In the event that Rancho doesnt have anything available there are other brands. I know RE makes a rear set that bolts to the rear lower bumpstop pads.(P# RE1387).however Hopefully Rancho can help you out. I know ill probly be upgrading springs in the fall to rancho coilsRancho- Do you make rear bumpstop extensions for this kit yet? I noticed the JL kit has the extensions. I definitely need some for my JKUR.
Synergy makes a perfect 2” spacer for about $50. If Rancho doesn’t have one I have no issues running the Synergy. Just thought I would check first.
Run 'em.We do not make them at this time.
:beer:
I installed the Rancho Sport 2”lift last weekend and it rides great. I installed a new steering stabilizer, but I am experiencing a bit of bump steer on uneven roads. I suspect the cast is out of spec, causing the excess bump steer. I’m thinking adjustable lower control arms would be my next logical step to solving this issue. Is there anything else I should be replacing along with the lower control arms?ATTACH]307174[/ATTACH]View attachment 307175View attachment 307176
Swapped out the short 9000 326’s for 329’s, added core tier 3 lower front and rear control arms, stainless lines, new sway bar links front rear, core tier 4 front track bar, 2” bump stops in rear. I must say the Rancho progressive springs are amazing so far. With just these basic modifications, the Jeep rides amazing, steers like stock, and flexes quite well. Very happy with this kit so far!
Swapped out the short 9000 326’s for 329’s, added core tier 3 lower front and rear control arms, stainless lines, new sway bar links front rear, core tier 4 front track bar, 2” bump stops in rear. I must say the Rancho progressive springs are amazing so far. With just these basic modifications, the Jeep rides amazing, steers like stock, and flexes quite well. Very happy with this kit so far! View attachment 308643View attachment 308644View attachment 308645
How much bumpstop are you guys running in front? Any rubbing? Still using stock drive shafts?
Couple of questions before I purchase. I have a 2017 2dr Rubicon with no options, I like the ride it provides, unsure to go with the 5000 or 9000 adjustable shocks, sure would welcome some additional feedback. Also want to add some narrow Nitto Trail Grappler's in 35 x 11.5 x 17 size with the required wheel spacers and possibly some lower control arms, should I anticipate any interference while road commuting?
