Majik
So this may be stupid, but what if you used the 2 sets of front brakes off or a ram, with a different master cylinder?
Not super familiar with dodge trucks, but all the fords I have had have rear drum brakes, would this account for the difference?
I'm using late-model setups only - only those that came from the factory with disc/disc setups. If I understand your suggestion correctly, you are asking what if I used a matching set of calipers front and rear, correct? That would be simple, however, would cause rear wheel locking/skidding under even just moderate braking. Rear calipers are designed with less piston surface area intentionally, because as you depress the pedal, weight shifts forward, unloading the rear tires somewhat, and making a skid much easier. Surprisingly, there is a huge amount of research that goes into selecting the correct front-to-rear piston size differences to make your front and back wheels brake well. That's where my spreadsheet has come into play.... I can list a dozen different combinations, and see comparison ratios front and rear and compared with the master cylinder bore.
Right now, due to the large 4-piston calipers I'm leaning towards at the moment, to mantain a similar-to-stock (or slightly firmer) pedal feel, it looks as if we may need a master cylinder with a 1.25" bore. Problem there is finding a master cylinder with a large bore like that that also isn't too large externally to fit in the limited space in the front corner of a JK engine compartment.
If anyone knows of a custom master cylinder manufacturer or where I can get a very short MC with such a 1.25" bore, please let me know. Thanks!!!!
