aermotor
You are going to need something to support on the hanger before the axle, not sure how that will work with that one. The whole system is heavy!
Did you order that magnaflow turndown or go a different route?
Everything fit on my 13 JKUR.I went with the Summit Racing Turndown exhaust tip. They were about the same dimensions but I liked the looks of the Summit one better. Summit part number SUM-691200. The entire kit runs $300 without tax.
Let's hope it all fits, right?
The PN for the tail pipe that dumps behind the axle is 55428
https://www.summitracing.com/parts/wlk-55428
Several questions about fumes were asked but I didn't find someone answering them. Anyone with the setup with the exit prior to the axle have any issues with fumes inside? How is the setup after install? Any further insights from those who did it?
No isssues with fumes at all for me. The only time that may even happen is if you are sitting idling with the windows open and it is completely still out. It's pretty much a non issue to me. When rock crawling or going slow there is typically enough air flow outside to disperse the fumes.
checking back in as this thread was up on the news feed... anyone have any luck tracking down magnaflows part number for the turn down tip?
Mine isn't that pretty, but in post 45, I showed where I cut off an elbow, I picked up at Autozone. It works, but could look better. I only had a 4.5" grinder with a cutoff wheel to do it.
Just to see how it feelsView attachment 264542.............
