You ladies gonna braid each other's hair too in between trails?
Rig is looking good, nice to see you out getting it dirty. We were just looking at a pressure washer. Anxious to see if it works out longterm. How much does it weigh?
Time to pull out the soapy water bottle.... good luck finding the leak! Great pictures :thumb:
Decided to re-wrap my cage handles yesterday, red wasn't bad but the driver side was getting loose and I couldn't fix it
I can try and get a real weight on it, but it is very light which really surprised me. Even just seeing the box at Lowes made me laugh a little at first. It had really good reviews online so I figure I would give it a chance, I hope it holds up well. My only concern is the hard water I have in my area so I may be running the pump saver liquid through very often.
You don't need to get a weight on it, I was mainly asking for ease of moving it around. Glad to hear it's light. Since you've used it, does it seem like it did a decent enough job cleaning off mud, etc?
So far I have only used the weird "twist" nozzle that it comes with....also have 4 others like normal....but it did a great job. The only complaint would be the hose so far which is what others said in the reviews but its not really that bad. Moving it around is more than easy enough since its so light (just looked at the manual, it says its 22.9 pounds). I should add it has enough power to blast off loose paint as well.
We've used our pressure washer twice, same model as yours. Agreed it could use more power, however, I think for the price we'll still keep it around. Still way better than a garden hose.
'Chemical guys' makes some awesome foam cannons. You just grave to make sure the compressor is strong enough
MY BUILT/REBUILD: http://wayalife.com/showthread.php?44123-Rebuilt-of-a-Billet-Silver-mall-crawler&p=859931#post859931
