Followed Eddie's writeup at http://wayalife.com/showthread.php?...K-Wrangler-Differential-Fluid-Change-Write-Up to change the fluid in both diffs this afternoon. Very easy to do.
Here's the front draining out. Liquid wasn't that nasty. Rear was worse.
Bought this for $3 at OReilly Auto which greatly helped with the refilling of the front diff.
Rear diff looks like there may be a leak? I check the bolts and they're tight.
Weird thing is that it goes up onto the bracket for those wires. Doesn't seem like that'd be the case if there were a poor seal on the diff cover.
Anybody have an idea? I wiped the whole diff cover clean; I'll check it over the next week to see if anything comes out.
That's pretty normal. You can keep an eye on it but don't worry too much. Long-term seepage, I don't see any signs of an active leak.
