Ok, so need some feedback from you guys on my “theory” on how my engine fire started.
Keep in mind that I had just left my house in about 55 degree temps, was about two miles away getting onto the freeway when I noticed a bunch of white smoke coming from behind me. If you look at the picture below, the heater hose has a two inch wide rupture (no visible fire damage) where the Sharpie is. The plastic fuel line was where the RED line is drawn, but it was sagging post-fire as indicated by the BLUE line. I suspect the heater hose blew, melting the plastic fuel line causing it to sag until a small fuel leak started a fire under the hood blowing it back onto the firewall and hood insulation. All the damage is centered in this area. In addition, those Gates heater hoses only have 15k miles on them and the thermostat is a factory unit with 4K miles on it.
Is that a plausible scenario? Or what are your thoughts, ruptured fuel line first?
Sent from my iPhone using
WAYALIFE mobile app
