Vacuum lines seem to be the first to go.  God forbid anyone just tries to find where one is leaking from.  Not as if these older rigs have that much under the hood to begin with.  Not like a 1980's CJ with CA emissions anyway.  They had miles and miles and miles of vac lines :crazyeyes:
I did and they were a bit loose and tightening them up did help.  Thanks.  However, I still had a hard shift into reverse and was able to isolate the problem to the idle speed being too high.  After bringing it down, it shifts much better.
The biggest problem I have right now is that from a complete stop, if I step on the gas hard, the motor quits.  In park and no load, I can step on the gas hard and it'll just rev fine.  While driving, even at a crawl, if I step on the gas hard, it'll accelerate just fine.  If I slowly accelerate from a stop, no problem - it only cuts out when in gear and when I give it sudden heavier acceleration.  My initial thought is that it might be a fuel pump regulator issue being that I'm running an electrical pump - maybe flooding the motor.  But I would think I'd see this problem in more conditions than just from a complete stop.
