Ddays
Is there a swap out there that does that?
I can do it, but you wouldn’t have power windows and door locks, stupid shit like that. The swap would probably cost a little more but it would be worth it.
Yep. I’ve said it before, and gave them another chance but the last 2 were noThing but trouble. The problem isn’t the LS itself, but the integration between Jeep and GM. A stand alone system is the only way to go.
Then it’s a trailer queen, if you live in a state that smog tests them, right?
You are correct in your thought process CARB is stupid.Gray area. Say you have a 2015 JKU and did this. So long as they engine in it meets the same or better emissions as the engine that was originally designed and produced for that vehicle, then I believe it doesn’t matter. That’s the straight forward answer and the most logical. Does this apply in California? I’m about 99% sure it does not because you know, the atmosphere can tell the difference between the engine that was in it before and the one that’s in it now.
In Nevada, emissions requirement vary substantially by county. Eddie and I live about 20 minutes away from each other but in two different counties. In my county, getting engine swaps (of any kind) approved is hit and miss and that includes Motech swaps. I don’t think you could get a stand alone setup approved here.
