DWiggles
Looks the same as the stock rubi rails. What kind of sliders are you going to get? I'm sure it's between the EVO and LOD.
LOD. And the rear Gen 4 carrier
Unintentional Thread jack... hehe
I'm about to chop my fenders and am looking for info on the best tool to use for the cuts. In Eddies write up he did a GREAT job with a dremmel, but I have also seen some fenders come out awesome with just knives. I would like to know what tools everyone used and "if I could do it again, I would have used..." so I can make sure to do it right the first time. Thanks guys!
I used a jigsaw. Would use the same again. Then underneath a dremmel and a sawzall for the bigger stuff.Here's the jeep with the sliders still installed. It looks to me any rear flex will rub the slider, so I took them off without giving them a chance to actually rub...
View attachment 191709 I used a jigsaw. Would use the same again. Then underneath a dremmel and a sawzall for the bigger stuff.
Just did mine today,.. THANKS Eddie for the great write-up and Pics, was VERY helpful. It turned out GreatView attachment 151306View attachment 151307View attachment 151308
@GraniteCrystal, no, I left the wells Granite Color... And it looks great! It's a little gloomy out today, but here's a few pics. View attachment 192207View attachment 192208
My friend finally decided to cut his fenders, we marked and cut the fronts this evening after work, moving to the rears and finishing off the fronts tomorrow
Yanked the Sahara fenders and cut a set of cheap plastics this weekend. Sorry for the poor pictures, will update with better later. Just need to trim and reinstall the liners.
Came out good.
I have used this cutting wheel with the Dremel. It cuts at a lower RPM and keeps the plastic from melting and flying off. It should be where the Dremel attachments are located.
What do you mean lower rpm? Rpm is controlled by dremel tool and will be identical between bits since it's a 1:1 ratio between dremel turning and bit turning.
