rockkrawlin4x4
Evening Guys,
Eventually looking to upgrade my stock suspension to 2.5-3 inches of lift with 35s on a 4 Door Manual Rubicon (AEV front/rear bump w/tire carrier). Currently, I tow an offroad trailer (8'x6'x4') that is about fully loaded 2,000lbs with 300lbs (350/3500 being jeep limits) tongue weight whenever I go "overlanding" in Anza Borrego/Mojave/Death Valley. Currently, I get sag with that I correct with airlift bags. They work, however I dont really consider them a long term solution and I'm looking to eventually lift the jeep. Couple thoughts come to mind such as OME HD (330lb constant load coils) or coilovers if they can have the preload set around 300lbs to compensate for the tongue weight (if this is possible?). I do a lot of offroading without the trailer so looking to find a good suspension overall. Any recommendations you have would be greatly appreciated....in terms of tongue weight, it's pretty set due to the construction and placement of a 260AH battery which I would prefer to not move FYI. Thanks.
