Carpet question
Be careful about using them at the same time. (Might want to make certain the adhesive remover is not flammable first so you don't go up in a ball of flames.):hot:
Oh no...Wont be doing that at the same time. Using the heat gun to get out as much of the pad/carpet as I can. Then will need to scrap off the leftover chunks. After that I will take the adhesive remover to the remaining glue and scrap off.....sand down the inside and then reseal it with some primer and paint.
That's horrible, never seen anyone glue carpet down in a Jeep :idontknow: Lots of good suggestions on how to clean it up.
