Carpet question
hbkid22
Has anyone ever seen carpet glued down on a JK before and if so any idea how to get it off? The guy who had it before me put in after market carpet but glued it down everywhere (even up the side).
Also any sealer/paint combos you like to? I will more than likely have to sand some off and don't want to leave the metal exposed. I will be putting down a bed rug mat after (and not glue it down).
And just in case your wondering. ImageUploadedByWAYALIFE1409793579.924246.jpg
Any help is appreciated! :)
That looks like a mess and will be a pain in the ass!
Tools needed:
Goo gone spray
Putty knife
Patience
12 pack and a loud stereo to dull the pain
Good luck. Gas will also work well but you would probably pass out from the fumes after like a foot of doing it.
Can't say I've ever seen that before. :shock: Can you heat the glue with a gun and scrape it?
After I get out the carpet and pad (yes there is a pad under to make it soft) I will try heat. They sprayed the whole inside with glue then put in carpet. Not just around edges, everywhere. ImageUploadedByWAYALIFE1409794843.303365.jpg
Can't say I've ever seen this either.
Tools needed:
Goo gone spray
Putty knife
Patience
You in Colorado? I'll supply the beer and I'll even get some American honey!!! :)
I might also be inclined to leave a flaming bag of dog shit on the seller's doorstep.
Who the eff does that to a Jeep?!?
If I knew who did this yes sir. The guy who owned it before was in PA. And I got it from a CO dealership who had no idea about it. But the price and miles where right.
Pls tell me the black part is not mold!
No it's not mold. Whoever installed this decided to spray adhesive everywhere first then lay the carpet. That is what was stick after I pulled off the carpet and pad. It's ridiculous and on top if all this I get major allergies/irritation when I drive with the top on and windows up. It's bad all around but coming out soon (I hope :) )
wow..that's insane. but! it can be removed- once you get off as much as you can you can use a heat gun and scraper on the sides to soften up a section at a time and use boiling water on the floor.
if you have some deep pots it'll keep it from cooling too fast as you pour it in the tub, let it sit until the glue starts to soften (about 10 minutes for common carpet glue) move any electrical out of the way and wear eye & body protection, the hot water may splatter. use a good scraper to remove the glue then you can pull the drain plugs and let the water out.
after all that glue you'll want to prep the tub by some light scuffing, self etching primer then maybe some high heat engine paint or similar. Since you're putting carpet back down it should work out well.
you've got your prep work cut out for you, cheers! :beer:
not sure if it would help or not, but 3M makes a very good sticker/adhesive spray remover. I know a lot of guys use dry ice for undercoating on floors but not sure if that would help in this situation.
Not sure either....I went and picked up a heat gun and some spray adhesive remover and will give that a shot tonight....I still have no clue why someone would do this do. :mad:
If I was in your position I'd buy a gallon of acetone and just start pouring it in there and get at it with a scraper and some sort of vapor mask.
Be careful about using them at the same time. (Might want to make certain the adhesive remover is not flammable first so you don't go up in a ball of flames.):hot:
