BABOOZLE
You don't have a plug kit in your Jeep? It's a easy fix.
I do. Les Schwab is 5 minutes down the road and an interior patch is a little more permanent.
Great shots in the snow. What PSI were you running in the snow?
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Thanks. Initially I was at 10 psi but later dropped down to 8 psi. The big lugs just didn’t do well on the ice. I never got stuck but was slipping and sliding more than others.
If you’re going to be in conditions like that all day, consider chains. They make a huge difference.
Those are extremely solid carriers. Great shots too out in the snow
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Beautiful pics. Washington eh?Made a few snow runs already. Nittos are ok in the snow. If the snow turns to ice then it’s game over. View attachment 356757
Ripped off the compressor. During the climb, the tone completely changed in the compressor and it was producing no air.
I tore it apart and found that both bolts that attach the connecting rod to the motor concentric were sheared. I called the ARB tech line and they said this was common with the older generation of twin compressors. That bolt has since been upgraded from a 6mm to 8mm bolt. They said it should be covered under warranty. Hopefully I hear back soon.
