Tire imbalance or death wobble?
Yes but why move back to the OEM stabilizer
The OEM stabilizer works better for the Jeep than the other products do. It works better because Jeep provides a warranty on the whole vehicle, and so it is optimized to avoid issues (e.g. electric steering) with their design.
Bob sez:
Take your Jeep to a tire shop. Have the "balancing" beads removed. Have the tires inspected for defects. If the tires are OK, have them properly balanced.
The above is what others have said since the beginning. Advice was ignored.
But maybe Metalcloak offers some other bolt on solution?
There was a bunch of stock parts still. With an unknown amount of life left. I figured I might as well cross them off while I can. The tires see smooth a when I bought it and nothing changed with them. So my thought was they could be the problem but I’ll check elsewhere. The drag link had slight movement at the pitman arm so I wanted to change that, and it’s cheaper to buy it as a kit with a tie rod and stabilizer than it is to buy them individually.
Just picked the jeep up from the road force balance appointment. They said they all balanced out. One had to be rotated to get it into the green.
It seems much smoother, but I need to get some more miles on it. Will report back when I can do so, on call at work this week so luckily I get to keep miles off mine.
Out of curiosity, what do they charge for a road force balancing of 4 tires? I've asked 4 tires shops in my area and they had no idea what a road force balancer was. Lol
When our shop did it like 20 years ago, it was by the hour. Pretty time-consuming to do it correctly. 1.5 to 2 hours usually. Shop rate then was about 70. Now nationwide average is close to 200/hour.
A shit ton. Dropped off four tires and wheels at the local garage they said the only way to balance 37s was road force. Oh ok pick them up the next day $320. WTF? Oh yeah they said thought you knew road force balance is 80 a tire. Was my fault I didn’t ask before hand I guess.
A lot of times you have to actually unseat the tire from the wheel and rotate the tire on the wheel to get it in the right spot. It's a pain. It's pretty cool technology but expensive.
That would mean that the wheel itself is not balanced (including the tire valve). There is a yellow dot on every tire which indicates its lightest side, which should be aligned with the tire valve. But if the wheel itself is way off, then that seems like a manufacturing defect.
Road force balance is 25/tire up to a certain size, then it increases slightly in price. They charged $75 per for this since they’re 37’s, needed to break them down, suck the beads out and remount.
After some further drive time it does still have a shake at around 52-55. Not nearly as bad as it was but it still shakes. I didn’t notice it last night when I drove it home at all which is weird.
Speed related shimmy is a balance issues.
Maybe try tire beads.
With all do respect…. F you lol
The road force numbers are as follows
RF started at 29 they got it to 11
LF 18
RR 19
LR 18
Is it possible for a tire to be bad even though it road force balances fine?
What wheels are you using? Are they lug-centric or hub-centric? Maybe your wheels are becoming uncentered.
With all do-do respect…. F you!!! F you!!! F you!!!
If you can imagine it, then it could happen. The tire can change its shape as it becomes warmer. When the tire becomes warmer, the pressure goes up, which will have some impact on the shape of the tire. If there is a manufacturing defect, then the final shape of the tire could be bad.
Tire balancing only evaluates the vibration relative to the hub while rotating. The tire could be square yet be perfectly balanced.
LF 18
RR 19
LR 18
it's possible for a weight to fall off, have had that happen many times within days of getting them balanced.
Take it back and have them recheck the balance
They’re rocktrix brand and are hub centric. What’s weird is for the first 3 weeks of my ownership there was no issue with vibration or shake. Then i did the lift. Drove it for another week or 2 and the shake started.
I’m not against changing the tires but I want to make sure they’re the culprit before dropping another 2k.
Today I was thinking that if one of your shocks was not working, then a small vibration could become major.
If the road is smooth, then a vibration is most likely due to tires/wheels since the suspension should not be reacting to anything.
Bob
