fiend
Tie rod is an inch higher. The main advantage though is if you didn't want to drill your OEM knuckle and add the DL flip insert you could swap knuckles instead. These knuckles are pre-drilled with a tapered bore from the top down for the drag link. And of course they're painted red for only the most hardcore of trail wheelers.
Got it. My knuckles are already drilled. The extra inch would be cool, but not 450 bux cool. The red color, on the other hand, could sway me.
