Has anyone done anything to adjust their steering stops or is everyone leaving them as they come? It's hard to tell if I have a reduced radius or not. Seems like it might be a little, but at least I'm not rubbing.
. should work fine, they use the same taper and as mentioned no need to use the taper bushing from your current se
. Those would be sweet on a PR44.
You have these correct? Looking at the picture posted I see where the tie rod hooks but where does the drag link bolt to it?
Can't see why it wouldn't work. Drag link end taper should fit just fine. You just won't use the insert that comes with Evo flip kit. If you already have the flip kit installed, you'll basically just take the old knuckle off and the drag link will install into the new knuckle.
I noticed the same thing - think that's a stock photo of a drivers side knuckle that they mirrored for the ad?
Pics below of where it mounts. Just like Reid's. While the pic above is mirrored for the ad, the newer ones come with a drag link hole for each side (I assume for the right hand drive non-conforming jeepers).
