Need immediate help troubleshooting!
ScoobyCarolanNC
I'm out at a marsh & just finished a terrible goose hunt. Put the key in the Jeep & she rolls over fine, but there are no lights on the dash and the wipers are on high despite the stalk being off. What the F do I do now?
Sent from my duck blind.
Check for water around TIPM/fuse box. My guess is water is shorting something. Keep us posted.
Totally dry no water at all. Not even a puddle. Thanks fellas. I'll keep you posted after I pull the battery.
Id pull the battery cables off for a few minutes and reset it
Oh boy Scooby. Is it parked in water? Can you push it to dry land and let her dry out for a bit?
That was my thoughts too, hope it fixes it up
^ A quick Google search confirmed that this fixed it for a lot of people.
That did it! Thanks fellas!
So I'm back home. My fuse box was totally dry & covered so I'm a little spooked as to why this would happen. At least all I had to do was take the negative off to reset it. The positive was well stuck on and all I had was a leatherman!
I've had the window thing before. Just shutting the Jeep off then on reset that. This wouldn't. I was solidly freaked out. Thanks again everyone.
Oh, one last note. Don't try to use Bing as a search engine for Jeep issues. I'm switching back to google.
Just curious, how old is your battery? Reason I ask is that I am running the original battery, bought new in '13. Just want to be prepared when these gremlins take ahold of mine🥃
3 months old. This was definitely fuse and/or ECU related. You're probably about due to replace it. If you go to advance auto parts they can test it & give you an idea how good it looks. I was not in the mood to drop $140 when mine went.
Have you ever had to reboot your computer at home for seemingly no reason - just freezes up? It happens but we're usually more forgiving of Windows than Jeeps.
