GoldenJK
Figured the repair today on Slaughterhouse deserved a thread. On the run today my front e-locker stuck and wouldn't disengage. Both front and rear would lock just fine and the rear would disengage okay but front wouldn't. The idiot light on the dash would just flash and jeep could barely turn. We tried unplugging the wiring, tried running in reverse, switch to 2wd, drove around real hard to "bounce" it free, raised the front wheels off the ground and tried spinning them back and forth. Nothing worked, still stuck, and as expected jeep will barely turn on pavement. Definitely not drivable on pavement.
Plan was to either pull the axels or remove the diff cover and see it we could free it. Thanks to slimebones who had a bottle of gear oil, we opted to pull the diff cover. View attachment 208922
Pulled the cover and with a flat screwdriver you can pry/slide the locker. H8Roads was doing that while I fired up the jeep to engage/disengage the locker. Did that and it worked. All free and able to drive to the bar for a cold beer.
Here is a picture of the locker I found on the web.
Something to note is you may be able to do this trail repair without removing the diff cover. Depending your cover, you can access the locker with a screwdriver stuck through the fill hole to slide the locker.
So a question.... We got it working and got home but now what? I don't want it to happen again so what repair is needed? Just pull the cover and clean it real good, rebuild the locker? Replace it? I've heard Jeep makes you buy the whole assembly which sounds expensive. Anyone with experience with this? Suggestions?
