Old Crusty- 1958 FC170
Since I've owned the FC the steering box has been leaking (which means it still had fluid).
So I decide to pull it apart to clean it up and add new seals and inspect it.
Here's a short video of how the manual steering works in these old jeeps. My FC has a Ross. All the parts to rebuild it can be purchased from omix or crown.
The bottom spline shaft is where the pitman arm attaches.
http://youtu.be/gdXCPci5B5I
Bolt in the center adjust the tension on the steering, you can make it loose or tight. It basically tightens up the sector shaft fork into the gear.
Here's a couple shots
Sector shaft and worm gear out. That's the end of the steering column
New seal
Messy work bench but the steering going back the together
Holy gigantic steering box batman! Those things come with cross steer or traditional style boxes?
Sweet eBay score too.
I'll have to take some pictures, it uses leverage from a big bell crank. Like pictured below. I'm slowing rebuilding the steering on it. Everything safety wise is very old. Once it's done I'll feel safer driving it into town.
