Fck 50" lightbar with poison spyder mounts. I think the mounts look cool but were not shaped right and I found it difficult to bend them to make them fit correctly. Especially for the price. View attachment 139798
What part of it wasn't shaped right? I want to check mine. Maybe I haven't noticed or mine wasn't messed up.
How often are you driving alone in the night?
My mounts were flush on the bottom and had a large gap at the top. The drivers side gap was more extreme and I just thought they should fit better for the price. Maybe I got a bad set or maybe my A-pillar is a little off. It took a lot of pressure to bend it in to attach the lightbar. I can't tell now that I actually got it flush with the pillar.
You use the rubbed behind it? Where did you run your wire? Most are cut to allow room for the wire to be installed behind the mount. Or maybe you got a bad set...lol.
Honestly it sounds right because that's how mine were / are :yup:
Yea I ran the wire and rubber behind it.
Same here. Mine sucked down when I installed my light but wasn't "flush"
I recommend Smittybilt Jeep Light Bars. They are very easy to install and it's durable too. Recently bought mine from 4wheelonline.
If you are on mobile, just tap the post you want to quote. That will bring the option bar.![]()
Lol........
