Jeep stabilizer bracket build.
Stevengrill
My buddy was putting a new steering stabilizer on his JK and needed the tie rod mounting bracket. $50 + $14 for S&H online was best we could find. I told him that was crazy! Below is a series of pictures showing you how I made his stabilizer tie rod mounting bracket.
(New to the forum, after a search of the forums I figured this was best place to put my post. Sorry if it's not.)
I first started with a raw piece of round stock with and O.D. Of 3" and length of just greater than 2"
Grabbing it in my vise with a v block I then skimmed the top.
Flipped it over and skimmed the back side bringing the part into 2" in length. I also put a 3/8" hole down center (not shown) so I can then bolt it to my 1,2,3 block for a quick fixture hold.
After that I brought the outside into a diameter of 2 1/4" with .050" step on either side. The flats are so the stabilizer has a flat spot to Bolt to, and also so when I skimmed and put holes in I would have flats to indicate the part.
After finishing length and O.D. I vise back up into my part, and indicated it for my center. Drilled and circular interpolated my I.D to 1.375" (factory JK tie rod O.D.).
After finishing contours and getting the shape of the part, I laid it down (on my flats) so I could pop my holes in. Six 1/4-20 bolts and one M12x1.75 for the shock. I counter bored my 6 holes to a full clean up. Then drilled all the way through for my bolt threads. Then I drilled half way through for my bolt hole clearance. Then I put in the M12.
After that program was finished I hand tapped everything. Doing the 1/4-20 at this stage is nice because the clearance holes are a good guide for straight threads.
After that I scribed a line and proceeded to cut my part in half (this part always makes me nervous!)
After that I needed to clean up my surfaces. Grabbed both halves in the vise on a set of parallels and skimmed for a full clean up.
Next I media blasted my part
Turned out great, and looked awesome.
Next, my buddy decided to paint it black.
Several coats later it was ready for install.
After some measuring and checking clearances it was good to go!!
Hope you all found this to be a good write up! First one ever, ha.
#builtnotbought
LOL
Just kidding.
Love the fact you built the part and documented it. I totally dig stuff like this. Even if it's a complete waste on a part that's not needed.
I always said the build is the funnest part of a project.
A lot of expensive equipment in those photos... Actually turned out nice though. It reminds me of a roll bar clamp.
Ok.. I'm gonna go ahead and try to build this one too.. Looks like it was way cheaper and more time efficient than spending 64 bucks! Ok.. So I think I need to buy a few more tools... I'm sure it'll be worth it.
I'm gonna go out on a limb here and say that all the equipment you have costs way more than it is to order the same clamp. Most of us don't own a shop like you do...........
Is this some kind of joke?
Why would it be a joke?
Thanks! Only took me an hour and a half to make so why not. Better off spending money saved on something else
Most people don't have welders and band saws, but people still write post of control arm builds.. I suppose all posts need to be like this?
http://wayalife.com/showthread.php?4349-MAINTENANCE-Jeep-JK-Wrangler-Rear-Brake-Pad-Replacement
#Loltroll
Had fun making it and thought it would've been cool to share. Rough community here.
#Loltroll
Lol wtf? That is brake pad replacement. Guess we know who the troll is. :crazyeyes:
Everybody should make a friend with a machinist. We get to play with some pretty cool toys, and make some awesome stuff.
Trade me/them for a couple beers and I'll bet you can get some custom parts you've always been wanting in return.
EXACTLY! You can seriously make anything, so why not. All I've been making lately is die pads, and as fun ( and I mean FUN) as 3Ding is, it was nice to make a simple bracket. lol.
P.S. that part looks pretty sweet, curious what its for.
While we all know the cost of tools to do something as simple as this out ways the cost of buying if you don't have them, Isn't this just like installing a lift your self to save the labor? If he had to pay for a machinist to do this the cost wouldn't be in his favor.
Nice work. To bad he painted it
I think thats bad ass!!! If I still had access to CNC's or even a simple Bridgport and lathe I totally would have built my own, vice paying 60 bucks for one like I had to!!!! It not always about the money, its about the experience and learning new a new process or tooling setup. Yea not everyone can afford tools like that (most likely he works somewhere and did this as a side job) but hey I still have a few machinist contacts and being able to call them up and have them build me shit is way better than buying it. At least until I can get my own machines!!!
Amen brother. It was a fun experience!
