computeruser6
I haven't gotten around to starting a build thread yet, but I wanted some opinions on what's going on with my rear axle and future plans. I had the lift, wheels/tires, front axle housing, and many other things replaced at around 10,000 miles. About 24,000 miles later I replaced the carrier and pinion bearings because the pinion bearing had significant play and was causing gear oil to leak. The pinion bearing was pitted, as if it was not getting lubricated and overheated. During my discussion with Off-Road Warehouse I told them that I used Royal Purple gear oil. The manager stated that they had seen several axles suffer the same fate that used Royal Purple and would not warranty their work if that oil was used again. Shortly afterwards, the passenger side rear wheel bearings seized. Enough heat was generated to burn my finger when I touched the hub flange and caused the axle seal to fail. When the shaft was pulled the rollers just kind of fell out.
A few weeks later I started hearing a low, but sharp metallic noise from something in my rear-end. I could only hear the noise when the Jeep hadn't been driven for a while. I thought it might have been some sort of brake problem at first, but that led nowhere. A few days ago I pulled the fill plug off to check fluid level, noticed a bunch of metallic shavings on a non-magnetic plug and didn't think about what that might mean until the next day. So I then pulled the drain plug and a shard of metal and a rather large amount of metal particles came out. I pulled the diff cover and noticed no more shards. The gear teeth I could see were fine, but I haven't gotten around to pulling the carrier yet. The Jeep drives normally, doesn't seem to be skipping any teeth. The shard seems like it's from a retaining ring or some other part that's not a gear tooth, though I don't know. When I used the lockers two weeks ago the front disengaged in a few seconds while the rear took almost a whole minute. I'm not interested in throwing any more money at my rear axle. Anyone have similar good fortune as myself or any guidance/suggestions?
I'm buying a Dynatrac semi-float Trail 60 (4.56 gears, ARB, stock width, 5x5.5 wheel pattern, 1350 input yoke) and am dumping the current rear axle. I wanted one anyway, I just didn't want things to go down like this. My front has been amazingly trouble free at least. I'll also be re-gearing the front axle and throwing some Spyntec hubs at it. Any criticism or suggestions would be greatly appreciated.
