Remove all the bolts, unbolt the ebrake
Check project-jk.com, there's a write up for the tuffy install
www.toasterjeep.com
Nope I can't get it off! I just walk out till tomorrow, I check all around no screws or nothing holding it I just can't pull that crap outx2 put it in 4lo and make sure the clips along the sides on the front are free then just wiggle it free...
You tube....yup.....
First, I prefer to leave the transfer case lever in neutral during removal. The lo position can cause interference when maneuvering the console out and back in. Next, have you pulled the parking brake lever up to its max position? As I learned, if the parking brake isn't all the way back, it will push the console forward making it impossible to remove.
