Just out of curiosity, what exactly is the point of keeping your Rubi sliders if you install a set of weld on sliders? :idontknow:
I just like the look. I know they will serve no purpose after the sliders. I just like how they cover up the pinch seam. I'll get rid of them if I cant find a good slider to reuse them.
Saw the LoD thread and it got me thinking about a set. I like the fact that the ace sliders work with the rubi rail, but the LoD has a step. Anybody using the ace weld on sliders that can attest to durability, appearance, install, etc.?
could always just paint the pinch seam black....its easy to hide.
Trying to think of the design of the ACE sliders and know the bolt-ons sort of butted up against the rubi-rails. If they were welded on, would you be able to drop the Rubi rails low enough to take them off...even if you wanted to later?
Yup, this! Exactly what I did. Though I also run the EVO rock skins, but I thought the bit of silver peaking out of the bottom looked off. Painted the pinch before the skins went on. But can easily see tapping off a line at the pinch and painting black.
OP... if you're going weld on at this point, why not just go with the EVO sliders? :thinking: Is there that much difference in price/style.
As far as the pinch seam goes, a little rattle can of black will fix that. At least, that's what I had done :yup:
EDIT: looks like hinrichs beat me to it![]()
I don't see the appeal to ACE sliders - they are kind of expensive for what they are, and the EVOs are not that much more expensive.
Sent from my SM-P905V using WAYALIFE mobile app
lol whats "level 2" protection.
Ace uses mild steel, Evo uses DOM.
:cheesy: I was wondering that as well.
It's exponentially stronger than level 1. ACE is better known for level 1 protection. You may recognize a few and even have some currently around the house.
It's not know if level 1 is compatible with the Rubi-rails though. :cheesy::cheesy:
