I have been back and forth about these two lifts for too long now. Does anyone run either of these lifts and if so did you encounter any problems, like replacing the front driveshaft? Need some help, I want the taller look and I know I won't get it with the 2.5 inch lift.
I was considering the 2.5 inch teraflex lift with shocks because I heard that was the best bang for you buck but if those coils ride stiff than which lift or combo would you suggest around that area. http://www.quadratec.com/products/16190_2500_07.htm
This is the 2.5
Should I steer away from teraflex because I want a smooth ride due to the fact that 99% of my driving will be pavement due to the fact that my jk doesn't have 4 wheel drive. Sucks.... I know...
Thanks for the feedback everyone, I want to pull the trigger soon just want to make sure I'm spending my money right. I want to run 33s or 35s down the road just for the look.
This is the 2.5
if you just want it for looks then i would look at the 2.5" budget boost they have with shock extensions. its A LOT cheaper, you keep your factory ride quality, and you get the look you want.
http://www.quadratec.com/products/16190_0005_07.htm
Evo coils are worth it for sure, I had the tf lift and got tired of the stiff ride so I swapped the coils out and couldn't be happier. If I was to do it again I just would have gotten the enforcer the first time around and spend a little more than upgrading almost everything from the tf 2.5" lift.
Why does everyone steer away from those body lifts though? I feel like using those to lift my vehicle wouldn't be as good as coils.
My other concern is the lost in height those longer coils provide, like Wayalife said a 2.5 actually gives you about a 3 to 3.5, that is if I don't add extra weight to it.
It's worth noting that since you don't have 4 wheel drive you won't have the front drive shaft issue
this isnt a body lift, this is a coil spacer lift. you retain your factory coils but add this spacer to the top of them. as mentioned this will give you exactly 2.5" of lift and keep the factory ride quality. i know a bunch of people on a budget that run this exact lift and a one other who runs it just for looks like you mentioned you wanted to do. go read thru this write up and you can see how it is installed :yup: http://wayalife.com/showthread.php?3976-Jeep-JK-Wrangler-2-5-quot-Budget-Boost-Installation-Write-Up
Teraflex's coil lift will give you about 3.5" because its so stiff. trust me, i run the 2.5" coil lift (and so did hinrich as he mentioned) and it got us that high but with a sacrifice of ride quality.
When you guys say stiff what do you mean? Most of my miles will be on highway so how will I notice the stiffness If the most I hit is a pot hole.
Also if I don't need to replace my front driveshaft because I don't have four wheel drive than can I go with a 3 inch teraflex lift without fear?
I appreciate the recommendation and I'm keeping that in mind I just feel like I won't get the look I want with that budget boost.
For me, I feel the stiffness mostly ON PAVEMENT. Speed bumps, pot holes, rail road tracks, drive ways - it just gets annoying but, that's just me. Bombing through the desert sucks too. On the rocks, you're going so slow that it makes no difference.
How big of a tire are you hoping to run? 37's? The TeraFlex 3" lift will yield you OVER 4" of lift and it'll look silly with just 35's or smaller. But, if you're going after that 1980's sky high look, that's a different story![]()
The biggest tire I'm aiming for is 35s, I'm not trying to go sky high, I just want to sit nicely off the ground but the reason I feel like I need to go with a lift bigger than 2.5 because most of the pictures I see of jeeps with that lift don't seem that tall. I might just need to see some better before and after pictures.
