cozdude
Guy with a Red 2-Door
I'll have to request quote from them. Would it be the same price from off road evolution as it would be straight from dynatrack?
prob not as they prob mark it up a little which is natural.
^^^ this. i got quoted from dynatrac last year sometime on a PR44. it had 5.13 gears, oem ball joints, arb locker, unlimited housing, custom length 30 spline chromoly shafts with full circle clips, and 1310 u joint. all for just under 4k. here is the invoice
JK44-1X3010-B
1
Custom Dynatrac Pro Rock 44 Partial Front Axle Assembly w/ARB Air Locker - '07-12 Jeep JK
3,837.00
3,837.00
General Dynatrac Axle
1
Dynatrac Pro Rock 44 High Pinion, High Ground Clearance Heavy Duty Nodular Iron Housing
0.00
0.00
1
Heavy Duty 3.0" Diameter, 5/16" Wall DOM Housing Tube Assemblies, Installed
0.00
0.00
1
Dynatrac Unlimited Pro Rock 44 Housing Upgrade, Provides Extra Caster & Shock Mount Relocation for 3+" Suspension Lifts - UPGRADE
89.00
89.00
1
Stock JK Axle Width - 65.5"
0.00
0.00
1
Dynatrac Heavy Duty 3/16" JK Coil Spring Suspension Brackets, Installed
0.00
0.00
1
Dynatrac Raised Track Bar Bracket Modification for High Steer/Flipped Drag Link Applications - Optional Upgrade = add $79.00
0.00
0.00
DA44-1X4033-F
1
Dynatrac Heavy Duty Pro Rock 44 Nodular Iron Powder Coated Differential Cover, Installed
0.00
0.00
1
Dynatrac Heavy Duty Pro Series 44 JK End Forgings, Installed
0.00
0.00
1
Heavy Duty Open Differential, D44, 30 Spline, Installed
- (Upgrade to ARB Air Locker Differential, Installed = add $439.00)
0.00
0.00
1
D44 JK New Generation 5.13 Reverse-Cut Ring and Pinion, Installed
0.00
0.00
JP44-4851-C
1
1310 U-bolt Style Pinion Yoke, Installed, w/Yoke Kit
- (Upgrade to 1350 Yoke, Installed = add $29.00)
0.00
0.00
1
Custom Length 30 Spline USA-Grade 4340 Chromoly Inner Axle Shafts, Fit Stock JK 1310 U-Joint
- (Upgrade to Heavy Duty RCV Performance USA Grade 4340 Chromoly Inner and Outer Ultimate CV Axle Shaft Assemblies w/RCV's Lifetime Warranty = add $796.00)
0.00
0.00
1
OEM JK Ball Joints, Installed
- (Upgrade to Dynatrac ProSteer Heavy Duty Ball Joints, Installed = add $499.00)
0.00
0.00
1
Customer to Reuse Stock Wheel End Components (Knuckles, Hub Bearings, Disc Brakes, Outer Axle Shafts, and U-joints)
0.00
0.00
Subtotal
3,926.00
Shipping Cost (FedEx Freight® Economy)
0.00
Total
$3,926.00
as you can see you can upgrade everything but that adds to the overall cost
WOWWW i like that number who did you call??
i called dynatrac directly. just note this price is without freight charges
Good thing I live down the street from dynatrac
no free shipping on a 4k order lol!
Installed? 4k would have to be using a lot of existing internals, knuckels, brakes, ball joints, etc. Not to mention the likely needed gear install.
Again, one can save a lot and maybe get that 4k if they do self install. But most don't have that high level of skill set.
- Jason
High level of skill? If you can install a lift lift you can install an axle.
I consider myself pretty good with installing most parts and some modifications but I wouldn't trust myself to setup the gears. If it was already assembled with the gears no problem but if I need to set them up I wouldn't feel comfortable.
I didn't say anything about installing gears. I said install an AXLE. You need to install gears either way so that cost is a wash and most places you buy the axle from will set the gears up for you.
You want to come help me.![]()
I personally couldn't install either at this point. I've seen it done and rather intimidating for a newb. Wish I wasn't so green, but it is what it is.
It's only a few bolts, my dad and I installed my lift and it couldn't have been easier. Definitely not worth the high cost shops charge to install!
My dad used to own car dealerships, so got a lot of exposure to the business side of the car industry, and I've spent a lot of time around cars/trucks my whole life. Helpful lessons used throughout my career. Wish I would have spent a little more time in the service/body shop bays. That would have proved helpful for my now hobby.
Generally speaking, install/labor is insane. I've got a lot going on with gears and welding of skids, gussets, etc. So at that point, not much more to have them do the lift while down there.
- Jason
What I'm getting at is if you can install a rubi 44 you can install a PR44 so the argument of cost of install is a wash. You need to do the same on both axles.
Gotcha, makes sense. I've installed everything on my jeep except my evo carrier and corner armor as nutserts and drilling into the body kind of scare me
I did my skins with a lot of help and nudging from some friends. Drilling holes in a perfectly good $37k rubi seemed crazy. But she looks bad ass now.![]()
