Pvanweelden's JKUR build
Bill S
That picture on dragons tail is one of my favorites.
Sent from my SCH-R830 using WAYALIFE mobile app
Army_Vet
Banned
I thought I would share a couple of things I did while installing my homemade fascia that maybe will help someone else as the inside nuts at the rear frame support become a pita. First- I tacked the washer to the nut, then welded a 1/4" Sq x 3" long piece to the nut.
With the washer tacked to the nut, it is too thick to fit into the opening in the rear support, so I took the grinder to the outside face of the nut, until it fit in the opening.
Then you push the Sq rod thru first, until it comes out the opening on the inside of the rear frame support.
Makes attaching the 2 bolts super easy.
I meant to tell you this is an awesome Idea on the nuts!
pvanweelden
Found a new feature on my jeep today that I didn't know it had-
ARF. Automatic Radiator Flush. :D
Apparently previous owner had switched out hose clamps at some point, and if you don't know already, these hose clamps come loose after a while :mad:
pvanweelden
Luckily, caught it in time, radiator was about 3/4 full still. I thought it was the water pump until I saw the hose :D
some melted wireloom was only damage.
pvanweelden
Got to spend about an hour tonight working on jeep stuff, so I let the sparks fly :D
And made 6 rotopax mounts
SaddleTramp
Damn Paul, glad you shut this down in time.
Nothing like a stinky antifreeze steam clean, that stuff smells about as bad as diff fluid on the hot parts. Can't wait to see what you come up with the rotopax mounts, I'd like to figure out a way to mount two to my PSC tire carrier.
Rebel JK
<img src="http://wayalife.com/attachment.php?attachmentid=71297"/>
Gotta ask. Did you upgrade to stainless clamps ?
pvanweelden
Thanks Scott! And yes, Wes, definitely replacing the clamps!
How's this for OBA? :D
Rebel JK
185 cfm will take care of business! We use exactly those for blowing pull ropes in through hundreds of feet of conduit for cable pulling.
pvanweelden
^ I had a feeling you would know exactly what it was :)
I think the 10 cfm from the york will be plenty :D
pvanweelden
Not for my build, but I made 3 sets of tire carrier brackets for the rotopax mounts today over my lunch hour :D
loscann48
Glad you pointed me to your build thread. Love your jeep and the stuff you have done to it. I'm in the process of attempting to build my own bumper. Looks awesome, and I think I've had my concerns about the treadwrights addressed. :thumbup::beer:
Sent from my SCH-I535 using WAYALIFE mobile app
pvanweelden
Here's a set of brackets after getting trimmed down. They will mount to an Lod carrier and hold 2 rotopax on both sides of the spare tire.
