Best of luck to you sir just do some research on long arm kits before you buy one. Ask on here if you want everyone has information and all information is usefull.
Are all of you guys replacing the ball joints yourself or having someone do it? I watched a YouTube video and it looks like a big job. I also have death wobble and haven't been able to correct it. It's been sitting in the driveway for two weeks now. I have a rock krawler steering system and a fox ATS on the way but this is really only so I can drive it to a 4x4 shop for tire balancing. It's been very frustrating
Death wobble can be made up of many things.....first not having your axel centered under your jeep can cause death wobble...
...negative caster in upper and lower control arms can cause it
When I took my 2012 jeep in for alinement they told me that they want to replace one ball joint to correct camber and caster. I have a 3 1/2 inch lift with 35 BF Goodrich tires. I did not want to replace just one so I am waiting during my wait I hit a bump and my jeep started to death wobble only done this once. I want and check all my steer joint only found some play in the drag link. When I jack up the jeep and pry up the tires I notice that the ball joints have a little movement in them the axle shaft move up and down when I do this. I guess my question is and my original plan before all the death wobble started was to replace all my ball joint and replace my lower ball joint with offset ball joints. Will this help with the death wobble? I figure it won't hurt. My second question is has anyone know about moog ball joint are they any good and should I put offset ball joint on it. What other brand of ball joint do you recommend? thanks for any help that you could send my way.
Well what would be the cause of death wobble on a brand new jeep with a rough country 3.25 lift ? Did some research even spoke with Dennis woods of teraflex bought a adjustable track bar and my problem was solved I don't know call it magic......lol
Lol ....They were tighten to the proper specs and so was the new one I put in.........I guess your right you are the professional .....I know m my work ethics and I always double check my work and never deviate from the instructions, but that's why I'm on here now so that you can show me the way (no joke) thanks Eddie just know imma be bugging the heck out of you about all my jk issues.....lol
Sent from my SCH-I605 using WAYALIFE mobile app
