Lifter/Rocker Replacement
Najamerson
I have a 2015 JKU Sport w/ 107,000 miles on it.
I'm starting to get all the parts I need to change out the lifters/rockers on my 3.6. Other than the lifters, rockers, and valve cover gaskets, what else would you change while you had everything broke down and apart?
On a side note, I recently changed the oil cooler housing, spark plugs, knock sensors, and thermostat housing.
Thanks in advance.
Thanks in advance.
camshafts
definitely use Mopar parts, they may run a little more but not the thing you want to redo because of cheap parts.
Recently had the driver side repaired, rockers/lifters cams
Aren't MOPAR parts what caused the lifter tick problem initially
I wouldn't say so; problem with mass produced parts yes, which is still a possibility with aftermarket parts.
my opinion, I didn't see an advantage to go with Melling, they are cheaper, but better?
Wouldn't surprise me if they all come out of the same Factory slightly different specs
I see what you did there. You tried to be sarcastic and funny.
No, seriously. I would bet the mopar part is the highest quality option for your Jeep in this case. For all the reasons that @jeeeep listed.
Also if you buy a seal kit for the valve covers, buy spark plug gaskets too. I replaced mine last weekend after they had been leaking for a while.
And the pcv valve on the passenger side. I did not plan on replacing it, but it was a real pain to remove, and it was totally wallowed out, so I picked up a new one.
Lastly, if you haven’t had the passenger side cover off before, I recommend taking the battery tray out. It makes access so much easier. Pull the battery tray out from the rear, towards the firewall. Easier to get past the fuse box.
Thank you. But, after seeing the price of a cam shaft and possibly needing 4 of them, it will be a bit before I'm able to get everything I need to fix this issue.
