They do look nice.I didn't notice anything when I put them on my JK. They look pretty sweet though![]()
There are strips to check your brake fluid, but I just do a flush when the brakes begin to feel soft, check this outGood to know, thanks. Was considering getting a set of EVO’s because I thought it would tighten up the soft brake pedal feel.
www.wayalife.com
I wouldn’t consider mine that bad yet but they could be better I’m sure. It’s pretty hilarious when I go to drive Robyns car and hit the brakes for the first few times- about lock them up. HahaThere are strips to check your brake fluid, but I just do a flush when the brakes begin to feel soft, check this out
Motive Products Power Bleeder
For those of you who don't know, Cindy and I started to have issues with our brakes not working while we were on the Top of the World trail in Moab. This is the same problem we had back during the New Year Kick Off Run and let me tell you, it's no bueno. Anyway, finally got a chance to wash and...www.wayalife.com
There is an improvement in braking and I cannot say how much is due to the steel braided lines or if they made any difference at all. I installed heavy duty JT calipers, discs and master cylinder at the same time. The original brake lines were 10 years old had over 150,000 miles on them and one had trail damage.Did you see a difference in brake feel with the braided brake lines?
Thanks for the update.There is an improvement in braking and I cannot say how much is due to the steel braided lines or if they made any difference at all. I installed heavy duty JT calipers, discs and master cylinder at the same time. The original brake lines were 10 years old had over 150,000 miles on them and one had trail damage.
I wouldn’t recommend replacing the OEM with steel braided lines unless the OEM brake lines need replacing.
