Ddays
Thanks, those are pretty similar to what I was looking at. Funny, they’re out of stock on ARB too.![]()
I used the Google shopping tab - there are several vendors listed but I didn't check them all
Thanks, Jerry!I used the Google shopping tab - there are several vendors listed but I didn't check them all
Why did not you send it back to Reel to begin with?Well it seems I finally have a balanced driveshaft. Got the JE Reel delivered late yesterday and installed it today. Had to change out the flange on the transfer case which was unexpected but easy. My “old” shaft on its third iteration and is “perfect“, according to the shop, is nearly 0.5” off straight at the spline shaft this new shaft is only 0.2” off. I do feel “something” at 75+ but I’m not going to worry about it.
Here’s a pic of the new Reel vs the locally made one. They’re both made with Neapco parts, but the parts on the old one seem to be much more stout. At some point I’m gonna send the old one to Reel to be fixed and I may just re-install it one as my main.
The Reel shaft is the new one I just received. It was the locally built one that i’ve been having issues with. I let them keep teying because I spent a boat load of money on it and didn’t want to buy a new one. Obviously pissed because I missed the NYKO 2026 because of it.Why did not you send it back to Reel to begin with?
Got it!!!The Reel shaft is the new one I just received. It was the locally built one that i’ve been having issues with. I let them keep teying because I spent a boat load of money on it and didn’t want to buy a new one. Obviously pissed because I missed the NYKO 2026 because of it.![]()
Thanks, Ben. I’m able to drive on the highway for the first time in two months, at least I have that. HahaNice! Hopefully fixes your issues!
If you ever got up to Utah, checkout Slyco Drivelines (https://slycodrivelines.com/)Well it seems I finally have a balanced driveshaft. Got the JE Reel delivered late yesterday and installed it today. Had to change out the flange on the transfer case which was unexpected but easy. My “old” shaft on its third iteration and is “perfect“, according to the shop, is nearly 0.5” off straight at the spline shaft this new shaft is only 0.2” off. I do feel “something” at 75+ but I’m not going to worry about it.
Just bring it to Drive Line & Gear in Reno next time you go that way. They will have it done same day.Well it seems I finally have a balanced driveshaft. Got the JE Reel delivered late yesterday and installed it today. Had to change out the flange on the transfer case which was unexpected but easy. My “old” shaft on its third iteration and is “perfect“, according to the shop, is nearly 0.5” off straight at the spline shaft this new shaft is only 0.2” off. I do feel “something” at 75+ but I’m not going to worry about it.
That did cross my mind. I need to get over there to see the gang… and buy more Frey. Great idea.Just bring it to Drive Line & Gear in Reno next time you go that way. They will have it done same day.
