The build of Ruthless
Yup! Front was easy as it already had a pigtail so just needed to run power and ground up to the factory aux switch wiring. Same with the rear locker, just used the wiring diagram and used pins 1 and 4 and ran them up to the factory aux switch as well.
Simple 👍
Lights are in, 1/2” spacer is in, new OEM drag link, diff fluid changed in the UD44, lockers wired to factory aux switches, and compressor switched moved to under the hood
Now to align
