WJCO
Meme King
It's seriously an addiction. If eufy had a subscription, there's no way I'd do it.LOL - awesome! As if I don't have enough already, I was temped to get more cams too![]()
Agreed! That it's free, I keep finding new places where I want eyes LOLIt's seriously an addiction. If eufy had a subscription, there's no way I'd do it.
LOL - awesome use for themThese new c35 cameras have been good so far. Moved one in seconds today thanks to the magnetic base. On another critter adventure.
View attachment 435612View attachment 435613View attachment 435614
The c35s only work with the homebase mini.Do you need at least one of the eufy home bases for the cameras to work?
The s330 that I see all come with a hardrive.The c35s only work with the homebase mini.
The e330 pros only work with the regular homebase.
Many of the others use local storage and homebase is not needed. The s330 use local storage in the camera itself. Once it's full, it overwrites. You can download important events at anytime to keep forever.
This is the one Eddie and I have. All storage is built into the camera. You can use wifi if you don't want to use the 4g plan.The s330 that I see all come with a hardrive.
Do you have to have that gay solar panel or can I just change batteries? What batteries does it use?This is the one Eddie and I have. All storage is built into the camera. You can use wifi if you don't want to use the 4g plan.
eufy 4G LTE Cam S330
Forever Power: Empower your viewing to go anywhere you desire. Enjoy 24/7 off-the-grid freedom with the upgraded solar panel and a powerful 9,400 mAh battery. Seamless Connectivity with 4G and Wi-Fi: Ultimate security with uninterrupted access. If Wi-Fi signal is lost, the auto-switching 4G...www.eufy.com
It comes with the solar panel. The battery is internal and rechargeable. So if you could do ethernet to usb-c , you could possibly hard wire it. I've run mine without the solar panel and it will work but doesn't last long. If you find a good spot for the solar panel, the power is essentially endless.Do you have to have that gay solar panel or can I just change batteries? What batteries does it use?
It’s not that I can’t find a spot, it’s that I don’t want an ugly solar panel hanging off the camera on the front of my house.It comes with the solar panel. The battery is internal and rechargeable. So if you could do ethernet to usb-c , you could possibly hard wire it. I've run mine without the solar panel and it will work but doesn't last long. If you find a good spot for the solar panel, the power is essentially endless.
Hardwired over Ethernet yes, plug, not so much. At least not easily. I could wire something in but prefer not to. I did see those solar panels built in but I would want to mount them under the eves and would be worried they wouldn’t get enough sun.Is hardwiring in a cam an option? If so, there are decent ones you can get. Also, they offer cams with the solar panel built right into them so they just look like they're a cam and nothing else. I have a few of these too and they work well.
The cams require very little sun to get them fully charged. The only side of your house that it may be a problem is the north, especially in the winter. Otherwise, I have a couple that only get a couple hours of morning or afternoon sun and they're always good to go.Hardwired over Ethernet yes, plug, not so much. At least not easily. I could wire something in but prefer not to. I did see those solar panels built in but I would want to mount them under the eves and would be worried they wouldn’t get enough sun.
Indeed the solar quantity is very low. It's crazy how little exposure they really need.The cams require very little sun to get them fully charged. The only side of your house that it may be a problem is the north, especially in the winter. Otherwise, I have a couple that only get a couple hours of morning or afternoon sun and they're always good to go.
That's good to know. The north side gets exactly zero sunlight in the winter. lol It was 50 degrees a couple weeks ago and there was still frost on that side of the house at 4pm.The cams require very little sun to get them fully charged. The only side of your house that it may be a problem is the north, especially in the winter. Otherwise, I have a couple that only get a couple hours of morning or afternoon sun and they're always good to go.
