ANOTHER WINDSHIELD Bites the Dust - What Number are You On?
This happened on our way home from Vegas
Had Safelite come out and they did a great job of installing the new one completely crooked and with the driver side upper corner raised above the frame. The factory seal was also rolled in several spots. I was working and didn’t check it before he left 🤦🏼‍♂️ Now for a warranty appointment.
The last time safelite did my LJ they broke my mirror compass and completly messed up the molding.
On the TJ and LJs they have a reel of molding then they hand cut it to length and I guess they ran out and just kind of used extra pieces to try to fill the gap. Like you, I was busy in the shop gave him a tip and didnt look at it until like 30 minutes later. They did not mention anything about them breaking the mirror or running out of molding. I immediately called safelite and they opened a case. Luckily they take before and after pictures so they clearly saw the mirror module was perfectly fine and old molding was cut to proper length before the replacement, and then they saw the mirror module hanging in the after picture 😂. Needless to say I had a new windshield installed again 3 days later, and the new tech apologized and was just as upset
View attachment 434624View attachment 434625View attachment 434626
What in the actual hell?? I don’t think I’ll ever use Safelite now
it's jacked that you have to buy a separate window protection plan because they decided to put tech in the windows.
Curious if all I would loose is AM/ FM radio and 4/5g cellular. The XM & GPS is on the roll age. I couldn't care less if the spy signal and am/I'm was lost. I use android auto for navigation and xm radio.
Jeep seems to use cellular to remotely monitor vehicle health, and to provide some firmware updates.
I'm pretty sure the antenna in the windshield is just for AM/FM radio. If you have adaptive cruise control, you would loose it without a windshield made to accommodate the cameras.
Correct. The windshield also enables the auto-dimming hi beam feature.
all unnecessary stuff.
Those that SHOULD have auto-dimming hi-beam either disabled it, don't have it, but either way think headlights are supposed to be in hi-beam mode 24/7
