2024 Jeep JL Sport Upper Control Arm Anger
Fattyfatcow
Hello. Yesterday I started my first lift kit. So one complaint I have on the 2024 model is whatever the heck is in the picture is in the way of the bolt. It took me easily over 30 minutes just to get the bolt out and then the same to get it in. I couldn’t find a video or instructions that showed this horrendously placed part, but i eventually got it.
Someone should so do a video for how to do a lift with the 2024-2025s or just how to get past this thing. I think everyone would be eternally grateful. IMG_6543.jpeg
**removes sarcasm font so relax**
How hard would it have been to take the vacuum canister off? Looks like a few bolts would have let you get a better chance to take that bolt out.
Or is it more complicated than that? Can't see everything from this angle.
Kind of what I was thinking. I see one nut and one bolt and with them off (and or any other that I can't see in the pic), I bet it would have been a lot easier to remove the control arm bolt.
Upvote 0
Someone should so do a video for how to do a lift with the 2024-2025s or just how to get past this thing. I think everyone would be eternally grateful. View attachment 428048
There are two bolts to remove on the mounting bracket that will allow you to swing it out of the way. You’ll be good 👍🏼
I’ll also add this is only on the 2.0 turbos.
Upvote 0
See I agree with the theory, I did that but then the cables are so tight that the movement is minimal. It would have required me really finagling my way up into the abyss to undo the Christmas trees.
The clamps were just all over the place. I went to sleep after doing that, then the track bar. Today I have to do my sway bars and the rear springs, shocks, and track bar. Then I can stop staying in a 150 degree garage
Upvote 0
Super easy but resulted in minimal movement. I’m honestly really shocked no one included it in their instructions anywhere. Mopar takes the easy way out and doesn’t have instructions as to how they install it
Upvote 0
If you say nobody says it in the instructions why don't you say it here? Or is finagling it out the technical terms for that?
Upvote 0
they are all solt lines going into it. once those two bolts are out as disiple pointed out it wil be easy to move.
It felt like all the lines were tight, plus my noob mindset made me fearful in forcing it. This was my first time doing anything to this level. Prior all I did was trailer hitch, new fog lights, and a steel bumper that I painted and attached. So this was me just trying my hand. I apologize if my fear is what led to this post (genuinely sorry if I’m just stupid and didn’t push hard)
Upvote 0
What the heck is that thing? Auxiliary coolant pump? Out of curiosity, what engine did your Jeep come with.
I get the frustration, but it would be helpful to others to have more context on the issue...ie additional vehicle specs, lift kit...
Just my 2 pennies. 😁
I go now!
Upvote 0
getting over the fear of breaking something never goes away, sometimes you have to look at it long enough and then you realize it's held in place by too many damn christmas trees, and the majority will never fully go back in place (that's what zip ties are for when you can use them)
Upvote 0
I go now!
Yes for the 2.0 4xe models.
Upvote 0
I go now!
It was truly just me doing a Clayton lift using the factory bolt. At that point, that’s just me trying to take the factory bolt out. So it was me basically using a screwdriver to get enough leverage on the two to even get it out. Then I used a crow’s foot to get it tight once I had it back up there. Gear wrench would work too. But you can’t ratchet it down without making space first for sure. Just a headache
Upvote 0
Hahaha I love this. Yea the Christmas trees went way deep up there. You can see the path they take. I wasn’t ready to go on that adventure.
Upvote 0
