Need to open up the pilot hole for the backup light, then prep it for powder coating. I’ve got a friend that can do that for me.
I got 6 amp resistors that are supposed to eliminate error codes. However, the computer thinks the blinker lights are out. I’ve got the resistor wired in the positive blinker wire.
ETA- Anyone have an idea why the resistor isn't working? Is it wired in wrong?
Started work on the taillightsView attachment 395558
The resistor is wired from the positive signal to the ground? If you just put a resistor in line it's not going to fool the computer. You need to jump from the turn signal to the ground to add load to the system. If it's just in line on the signal wire your LED doesn't pull enough power for the resistor to have an effect.
This has been working for me for several years now. Just make sure the resistors are mounted on a heat sink. If they hang they will melt anything they touch within a day or two.
Thanks. Your advice did the trick!
My wife (aka Bunny's mom...the Jeep is named Bunny) noticed a few rock chips in the paint and those were obviously caused by the wide tires sticking out, so we ordered the Mopar Xtreme Recon flare extensions and I installed those a couple hours ago. They fit perfect, look great and was extremely easy to install. Hopefully, fewer paint chips now.
I got the new 40s on, changed out my front grill, & took some photos next to the twin prop. Haven't done much else to her lately.
Finished wiring up the LED tailights and installing the Motobilt taillight plates. The plates have been rattlecanned to keep them from rusting until I can get them and the grabhandles powder coated
Be careful. I got in trouble for posting a youtube link
