So I picked up this 2011 JKU Rubicon. The drive home was terrible but I saw potential in the jeep. It’s till hasn’t been back on the road after tightening up the steering box and loose steering wheel linkage, and replacing all of the RE control arms because the super flex bushings we’re all shot. Yes, I could have just replaced the bushings but time is of the essence and apparently I like shiny new parts.
This is my first experience with a coil spring jeep. From what I have researched and measured it appears to have 5.5” of lift. (Currently measures 10.5” between front axle tube and frame). I know that’s a lot for a short arm lift. My next step should probably be geometry correction brackets for the front lowers. I’ve attached a few pictures of the front steering components so some of you can hopefully tell me what has been done there and what needs improvement.
the front lower control arms are sitting at about 14 degrees of angle right now.
