cinnur
So I have installed my aftermarket rear bumper, and I thought I would share my choice of plate relocation so that it might help someone else if trying to decide on an option.
I went with the Fishbone Shackle mounted License Plate Bracket, Quadratec LED License Plate Light, and a bolt on D ring mount.
Parts for links if interested,
www.fishboneoffroad.com
www.quadratec.com
I like the Fishbone mount because it feels very rugged, and has four mount points for the plate. The Quadratec LED light is not very bright, but it fits simply into the need and comes with an adapter to plug it right into the existing connector for the plate light, there is also plenty of extra cable if needed. As to the D ring, drill the needed holes and your good to go. This setup seems to be very strong and hopefully will last.
I did find this plate mount from EVO, https://discipleoffroad.com/EVO-MFG-JLJLU-BODY-MOUNT-LICENSE-PLATE-LEFT-BLACK_p_1351.html but choose to not use it. I did purchase it and it is a solid piece of metal, but I was not sure of the single mount point to the Wrangler body, and only two mount points for the plate. I also was not sure on the idea of the plate and kit being close to the body if it were to get bumped and possibly cause some damage.
Why didn't I just use the existing shackle mount on the bumper, I did not want to give up that location for a plate relocation.
Of course all of this is subject to personal likes!
Shackle Mounted License Plate Bracket
Quadratec LED License Plate Light for 18-21 Jeep Wrangler JL
Happen to purchase an aftermarket bumper for your Jeep Wrangler JL and now you have no license plate light? Quadratec has a simple solution with the LED License Plate Light kit. A quick plug-n-play installation designed specifically for your JL that plugs directly into the factory original harness.
