WJCO
Meme King
Do it.Couple questions. The GM ecu isnt needed right? It gets replaced by the mocan unit and links into the factory jeep computer?
Also how's the 10 speed compared to what your previous jeep had?
One disappointing fact is that this was not the single module system so it looks almost the same as my old swap. With the single module system it's the Jeep ECM that goes away.Couple questions. The GM ecu isnt needed right? It gets replaced by the mocan unit and links into the factory jeep computer?
That's really interesting to hear. Do you have an HP Tuner?One disappointing fact is that this was not the single module system so it looks almost the same as my old swap. With the single module system it's the Jeep ECM that goes away.
At this point the ten speed needs a little tuning. The vehicle speeds are off by about 5mph so it shifts a little funky some times. Overall though this set up has much more go than the last one. I found you have to let up on the throttle when it shifts. The torque when it upshifts will push you faster if you don't let up a little and after 4 or 5 gears you realize you are going a bit faster than you wanted to be. (Not a big deal when you get used to it)
At the Endo of the day it just needs to be tuned in for the jeep not an Escalade. It'll take some time but I think it'll clean up nice. I'm still waiting on the atlas anyway so I've got time to play with shifts and such.
I do. Just need to do the data logging and get it set up right.That's really interesting to hear. Do you have an HP Tuner?
Cool - Be interested in what you do.I do. Just need to do the data logging and get it set up right.
The biggest thing I need to do at this point is get the gears and tire size in the TCM and that should fix the shifting.Cool - Be interested in what you do.
Do you have the stock tune for the trans? It's kind of a bummer that you can't just download what's there on a 10-speed.The biggest thing I need to do at this point is get the gears and tire size in the TCM and that should fix the shifting.
Oh no, that's great. At least you already have something to work with. I was just saying that if you didn't have it, you wouldn't be able to download what's there.I do but stock is like 3.73 gears and 30" tires so I have to get all the measurements and write the new tune to the computer. It's like 10 mins of work I just need to go do it. I'm just getting everything unpacked and situated from the shakedown run but I'll get to it.
No I've got the stock reads out of all the computers already. Just need to start poking around and changing values to get where I want to be.Oh no, that's great. At least you already have something to work with. I was just saying that if you didn't have it, you wouldn't be able to download what's there.
Nice, congrats on the Atlas! Yours will turn tires before mine does in the 8.Had some boxes sitting in the driveway when I got home today...
Seems irrelevant at this point. As long as they're ready when the snow melts it's no difference.Nice, congrats on the Atlas! Yours will turn tires before mine does in the 8.
