Oh shit. I am running the same setup and no issues.1500 miles and my new seals are leaking already. 35 Spline Nitro shafts in ProRock 44.
Noticed this groove worn into shaft when I replaced them last time. Thinking that’s the cause of my leaks. Shafts have roughly 27k on them. Anyone having issues with this?
Sent from Lookout Mtn.
Ive seen stuff like this on higher mileage vehicles...like where a rear main seal grooves the crankshaft, etc. Is this occurring on both sides? Any chance of axle shaft or seal being the wrong part number?
Yes sir. Both sides were leaking when I replaced them. Just the passenger side has started leaking again. May have to buy a spare set and send these to a machine shop. Doubtful Nitro will do anything . I have had them about 2.5 years, just haven’t put many miles on them.
Well that stinks.
Once the shafts get the grooves, you’ll struggle to keep them leak free even with new seals. Machining the shafts down to just below the minor groove diameter may make it worse as the OD of the shaft will be reduced at the seal contact area and may leak even more. Sounds Like new shafts are in order.
Being in the machine building and repair business, we see a lot of that. I suggest you find a local industrial chrome plater. Many have grinding capabilities or partner with a shop that’s close by. They will grind the seal contact area, chrome it up and re-grind back to size. Going directly to the chrome plater should give you the lowest cost since their overhead is usually less than your typical machine shop.
The chrome plating is much harder at >70rc vs the heat treated chromoly shaft material and should hold up for years.
Good suggestion. I’ve had a few pump, motor and fan shafts repaired over the years with flame sprayed chrome and tungsten carbide coatings. The shaft usually holds up well afterwards. The undercut area would likely become the new weak point though on the Jeep shafts due to the reduced cross sectional area.
I would not weld up the axle shafts, as this will affect the heat treatment and change metallurgical properties in the heat affected areas. You could go back thru the heat treatment process but you’ll have increased costs associated with it and likely will not have a straight shaft afterwards.
I agreed on the welding, it will distort the shaft in most cases. Pre-heating the shaft prior to welding may help, but it’s risky.
The shaft would only require minimal grinding so I don’t think the weak point will be an issue. I would grind the damaged area to .006” (inches) on the diameter or until the groove disappears. Chrome plating doesn’t need to be very thick for adhesion. I shoot for .003” minimum thickness after final grind.
It sounds like you are on the right path.
I suspect the groove may have been caused by mud getting in the housing, and some getting stuck in the lip of the seal, grinding its way into the shaft.
Yeah I could see that.That would have made the cost easier to justify [emoji23]
Bubba is backJeep rarely gets in the mud. So I don’t think it had anything to do with it. But I may wrong.
Makes me question the quality of the shafts
