CB wired up. Did not have time today to tune the antenna so tomorrow it is.
Simple and easy install. Two spots were a bit of a pain to run the antenna coax through. I opted to follow the roll cage up. Passenger rear seat belt bolt to the bar needs to be loosen up as well the area by the B pillar, there is a clip in the way if you want to run the cable behind it is where the install gets a bit tricky other then that no issues.
Ran positive wire to the engine bay behind the rubber on the A pillar as shown. Negative was grounded to the stud as sown. CB bar is great. Ran the wires right through it.Have to tuck the wires a bit behind the radio tomorrow as well. IMG_9241.jpgIMG_9239.jpgIMG_9244.jpgIMG_9246.jpg
Ran positive wire to the engine bay behind the rubber on the A pillar as shown. Negative was grounded to the stud as sown. CB bar is great. Ran the wires right through it.Have to tuck the wires a bit behind the radio tomorrow as well. View attachment 353363View attachment 353364View attachment 353365View attachment 353366
View attachment 353369View attachment 353370
Looks good man, I haven't decided which way I'll run that antenna coax yet. Cobra looks good too. I opted for a smaller CB cause the wife bitches about he big one. But think I'll hang a race and the CB off the bar. Looking fwd to seeing How the Rusty's carrier sits when I get it installed, to get the antenna through the gate and mounted up. I may get everything ran but not plugged up so it's a simple finish when I get the carrier in hand.
Sent from my HD1905 using WAYALIFE mobile app
