Voswitch install. This is pretty straight forward mount the relay/ fuse box find where you want the switch pane wire it up and good to go, there are two dip switches located next to the fuses, they come set to turn off if voltage drops too low (battery saver) and for constant power (have to push the power button to turn on/off) you can also set it to turn on with vehicle key power and comes with the wire and add a fuse to do that. I left it factory settings
Instructions say it’s waterproof and dust proof and recommend putting in the engine bay. I wasn’t a fan of any of the places that it would actually fit, so I decided to put it in the dash
By some miracle the space below the steering wheel is perfect sized for it, but it won’t be easily accessible, will have to take the dash panel off to pull it out and get to the insides.
I’m fine with that, it’s a couple screws and a few zip ties.
Made a couple brackets
Fits perfect. Steering wheel still had plenty of room to tilt and everything will tuck up nicely.
Since this spot is a pain in the ass to get to and I like having all my connections behind the glove box for quick access if needed. I decided that I was going to hook up all the wires and run them over to the passenger side where I can hook them to accessories instead of fishing all the different accessories to under the steering wheel.
If you’re new to wiring a couple tricks. Use a vice or vice grips to hold onto one side of your wires put the other in a drill and tighten loosely then spin the wires together to make them easier to handle and cleaner.
Make them even cleaner by using expandable wire loom with shrink tube on both sides to hold together.
Hook up the ends (and remember which color wire goes to which switch)
I decided to put the panel here for now. I might move it above the mirror later on we’ll see. Screwed into the trim and it’s adjustable on the ram ball style mount.
FedEx finally showed up with these 4 days late.
Centers are white and outside are ambers that flash. 3 wire setup so you can run them independently of each other.
Mounted and ran all the wiring underneath the windshield cowl and drilled a hole through to above the fuse box where the hook ups are now.
Mounted and tidy all the wiring.
And picked out my 8 stickers.
First impressions, I like almost all of it., I really like the customizable output by a quick press of buttons to change. Any switch can be
On/off
Momentary on
Slow blink
Flash blink
Flash pattern
Strobe pattern
Can also choose the backlight color as well as brightness however for my dash will likely stay red.
