Majik
I'm still reading this great thread for the first time, but wanted to say that Aluminum is going to be 'stiffer' than a steel plate and should minimize deflection under heavy load. I certainly don't know the specs or metallurgy of the steel used, so can't say this is for sure, but...
I worry about a few things with aluminum, though: corrosion due to dissimilar metals being placed in direct contact (although paint can slow this), differing expansion rates when heated, and fatigue. Aluminum fatigues with every stress it endures. Steel has fatigue limits that, if never exceeded, mean that it should never fail due to simple fatigue cycling. If I'm remembering correctly from my materials science classes...
I'd be hard pressed to imagine a 1/2" or thicker steel plate that is only a few inches by a few inches in size flexing enough to cause an issue. Point taken, and probably significant if I was using 1/4" or thinner, but in this case....:idontknow:
