Bigtmiller
So what is the favorite air down tool?  So many to choose from.
			Valve core removal screwdriver.
Locally available for $3 or less at any auto store.
Here is what I made and use regularly for airing down. Nothing fancy but works well and allows me to check the pressure while deflating.
https://wayalife.com/showthread.php?t=7529
I've always used the Staun deflators https://www.amazon.com/Staun-Automa...argid=aud-801381245258:pla-568351621102&psc=1
but I may try the ARB.. Just because
The Stain are good, but the knock offs are hit and miss. I bought a set of the cheaper ones and was disappointed. I could not get them to hold a consistent setting below about 15 psi.
The real ones work good, and allow you time to roam around and talk to people instead of going from tire to tire trying not to let out too much.
I had a set of knock off stauns for a while. They worked ok but would come loose and the pressure setting would get screwed up. A friend gave me his old set of real stauns, which I used for a while. They’re definitely better but have the same issue. I recently got the JK innovations 4 wheel kit. Although I’ve only used it for one multi day trip so far, it seems awesome for airing down and up. Especially the latter. No more squatting by each wheel to fill up. Just attach the four lines and go chit chat with your buddies while all four tires fill up. Money well spent.
I've been looking at that kit. Quality up to par?
