COUNTDOWN to the Final JKX : MOBY Rides Again
Okay, after getting Moby back home, I found that his rear axle was just sitting at about 1/4" more out to the passenger side. I then adjusted his rear track bar so that his axle will be sitting approximately 1/2" out to the driver side and then took him back out to flex him out. As you can see, this is full droop on the driver side and stuff on the passenger side. This is where we were having problems before but with the track bar adjustment and removal of the one gas tank skid bolt, all is good now - no more driveshaft contact.
So, this is where we were most concerned - full stuff. Being that we no longer were running bump stop extensions, there was a very real possibility that we'd slash the tread of our tires when crossed up. Mel had said that running 500 springs should prevent that from happening and what a surprise, he was right.
Pushing further ahead to cross Moby up the other way showed us that things were still good.
As you can see, Moby's limiting strap is taught and if you can believe it, his air bump isn't even making contact with the axle.
Upward resistance is all being done by the heavy spring rate - no rubbing.
Now, I should note that what you're seeing in this pics are static shots of opposing flex. This is kind of what you would see if you were to ramp your Jeep on one of those trailers with table jacks. This is NOT the same thing as what you would see when MOVING through an obstacle where things like force, gravity and inertia are added into the equation. With me taking on something like this obstacle like normally would on a trail run, the rear did stuff more and enough to the point where the driveshaft did still make just a bit of contact but down the smooth side and not to a point where I'm concerned. Also, the tread got real close to the rear corner of the wheel well but it did not touch. Of course, these are a worn set of Cooper STT Pros and a new set might reveal a different result.
Time to get more work done before the JKX :cool:
So much flex! Great breakdown of what you guys did. Everything’s a process, but looks like you guys are getting close! Can’t wait to see Moby preform at JKX!
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Thanks, pretty happy with the flex and with the performance we should be able to get at high speeds. Just got to address a whole host of "old Jeep" issues or at least, get what I can done and hope the rest will hold out. :crazyeyes:
Keep the pics coming! Looking great!
Just fixing stuff and doing maintenance now. Hope to get more pics soon. With any luck, by the end of the day.
It is never enough of Moby porn indeed
Love the flex [emoji7][emoji7][emoji7]
Lol. Tempted to Google that phrase just for kicks.
:cheesy: :cheesy: :cheesy:
Man that is awesome! I need to do this!
The amount of flex you get out of it is essentially the same - it's in the high speed big hits that this setup should really shine :yup:
Looks awesome. Can't wait to see you guys put him through the JKX paces.Damn it, you made me look. Kinda like a where's or not where's Waldo...haha.
:cheesy: Just hoping I can get to everything I'm wanting to and that he holds together :)
I’d say Moby has a tad more flex than in the 1st video on the WAL YT Channel!
LOL - talk about a blast from the past :crazyeyes:
It’s kinda sad to think the last JKX run is like a final note to the JK song...looking forward to seeing it with another of your video series.
Might there be a JTX someday?...
So today, we got a lot of things done including more maintenance like greasing and servicing the diffs.
And, while I was doing that, Cindy spent some time cleaning up Moby’s wheels.
Well, the center of the wheels look like new LOL
