sipafz
I mentioned awhile back that my air conditioning compressor apparently froze tight. I find this a bit strange since I hardly used it since new in 2016. That being said, I’ve used the defroster plenty which means that the compressor is engaged during those times.
Symptoms were:
At freeway speed, turn air conditioning on, but no cold air.
At idle, turning on air conditioning kills engine or belt slips at compressor.
The simple fix was to simply unplug the compressor so I can use the defroster as needed.
I’m now ready to start giving this issue some attention, but I’ve never serviced air conditioning other than to add freon and stop leak from a can to a different Jeep.
I appreciate any help or advice to the following questions:
1. Is it possible to bypass the compressor with a shorter belt? I would like to be able to drive the Jeep while servicing.
1a. If so, does the idler pulley between the compressor and crank shaft need to be removed?
1b. If so, does anyone know a part number or length for a shorter serpentine belt that would work in this case?
2. Has anyone taken a compressor apart? Any tips or tricks?
3. Has anyone seen any drawings, exploded views or parts lists?
4. Anything else I need to be aware of?
Thank you in advance,
Chris
			Symptoms were:
Chris
