wjtstudios
If he stuck with 37’s then 12.50 would be my guess going to the nittos
You can make out the #7 x12.5” in the picture of him mounting the tire. Must be 37s.
2015 JKUR AEV JK350
1985 Jeep Scrambler
What about passenger side? Granted, contact would be most likely if springs on both sides were compressed at the same time, which maybe is unlikely unless you’re doing whoops.
That's crazy close, still pretty tight. But at least you'll be able to make it home! It looks awesome!
Glad you got it all worked out. Can’t wait to see the pictures of it on the ground
2015 JKUR AEV JK350
1985 Jeep Scrambler
Looks awesome Eddie! What width tires did you resort to, 12.5s? How much travel do you have front and rear now? How does that compare to stock?
2015 JKUR AEV JK350
1985 Jeep Scrambler
I’m interested in what you think of the trail grapplers as compared to the SSTs.
2015 JKUR AEV JK350
1985 Jeep Scrambler
That's good at least, it looks awesome man! Sure you can't wait to get it out on the trail!At ride height, we've got plenty of room. We were just cycling the suspension to make sure we'd be good even at a full droop.
Wow! Awesome Mel was able to come through. Made in the USA is important! [emoji631][emoji631][emoji631]
We've run Trail Grapplers in the past and always thought they were good tires. Really, it's the only reason why we decided to go with them again. I mean, we could have easily gotten home with what we had and just ordered up a set of 12.50 wide STT Pros. The only real downsides to the Trail Grapplers is that they only come in a 12.50, they're physically smaller than an STT Pro if by just a bit and have a radial pull to the left. Otherwise, they're a good looking tire, hook up well on the rocks and maybe have a longer tread life.
