I’ve been reading a ton on this topic with some saying both need to be parallel to each other and others stating they should be as horizontal as possible.  I’ve even called companies asking what angles they should be for proper geometry but I never seem to get a definitive answer. Closest I can find is taking a string from end to end of the track bar/drag link and comparing the angles that way.
My track bar bracket has holes for a 3.5” or +4” lift and I’ve noticed there is a difference in handling. So with that being said instead of the string couldn’t you just use an angle finder? And why does there seem to be no right answer to this?
