Jkusilverbullet
LOSER
If I upgrade to the 3” plush ride springs, do I need to get larger bump stops than the ones that came with the TF 2.5” lift ? Have trimmed stock fenders
Not necessarily because of the coils, you want to dial in your bumps to your tires and any other aftermarket components (flipped DLs, track bar brackets, etc...). With a front track bar bracket and DL flip you need at least 3" bump stop spacers in the front. I run 3" front and rear bump stops in preparation for 37s, 2" in the rear should be fine with 35s, but you'll need at least 3" regardless if you're doing a DL flip.
