I like the way the new head unit looks! Did you install or have it done?
Installed it myself and it was very easy. All you have to do is remove maybe 6x7mm bolts, pull out the factory radio (I had an aftermarket already though), plug the new one in, and put the bolts back in. It comes with the dash trim so it's a direct bolt on. I'd recommend it to everyone; it's awesome!
Well it turned out great!! How big is the screen?
Floor Mats and Tail Lights
Floor Mats by Husky Liners
LED Taillights by Spyder
All from the 4 Wheel Parts Truck and Jeep Fest in Long Beach California directly from the vendor
Husky Liners X-Act Contour
Spyder Sequential LED Taillights
:yup::yup:
No, yet I need to move the sway bar back an inch. I don’t notice it causing an issue. Though, it says it’s required
I had all sorts of issues with my x factor rear set up to the point that I just ripped it all out kept the springs but put in Currie uppers and stock lowers and put the swaybar back in the original stock position. And I'm not the only one that did that so you may want to read up on that
